How to paint raised lettering on tractor
   / How to paint raised lettering on tractor #1
krogers
ford jubilee
Have any of you learned a good way to paint the raised lettering on tractor body work? I have been trying to find a way to do this on my Ford Jubilee. I tried using a sponge with paint on it by lightly pressing onto the letters but that did not work. I see decals advertised. I will research if that would be an alterative. Thanks.
   / How to paint raised lettering on tractor #3
You might try this.
Apply grease to the lettering - then using a firm sponge with an absorbent cloth, wipe the grease off the letter surface you are wanting to paint (spray). Wipe with a solvent also to remove grease before painting. Spray the letters and let dry - then remove the rest of the grease. I used to do this for parts of a car when I spray painted the car.
The decals sound good also.
   / How to paint raised lettering on tractor #4
Or tape over the entire area & cut out the letters from the tape shield with a razor knife.
   / How to paint raised lettering on tractor #5
All my life I've been curious how Ford did it at the factory?
   / How to paint raised lettering on tractor #6
I think they also sell a spray "blocking" that dries to the consistency of contact cement or light rubber. Spray off the area & cut out the letters to make a temporary stencil. then remove the rest when done.
or
   / How to paint raised lettering on tractor #7
Painted letters with a brush. I had old tractors with brush marks. You could tell as it was fading away. Just paint hood or whatever, paint raised area with a brush. Easy.
   / How to paint raised lettering on tractor #8
I used a foam roller, still needed a rag with thinner to clean some areas.
David
   / How to paint raised lettering on tractor #9
Interesting replies. (y)
   / How to paint raised lettering on tractor #10
TIRE INFLATION CAGE (A55745)
TIRE INFLATION...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
16' Cattle Guard (A53316)
16' Cattle Guard...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
