Wakey
Veteran Member
- Joined
- Jul 7, 2013
- Messages
- 1,164
- Location
- Madison Georgia
- Tractor
- John Deere Z915B Zero Turn 54 Deck
We had someone crash a truck through 2 sections of fence and nine 4x4 concreted fence posts were snapped at the base.
I did not want to dig these up figuring (it was too much work) plus it would disturb the ground too much right where I wanted to put the new posts. I did not want to have posts next to the broken ones because I am far too much of a perfectionist to do something so half-azzed!
I purchased a D-Ring tie down and 2 8"x3/8 lag screws and 4 washers. ($10 bucks) I used the washers to keep a good offset from the "tie down" so the socket wouldn't strip the bolt head.
I didn't even bother drilling a pilot hole I simply drove the lag bolt in with a torguey drill and socket. It's very important in my opinion to lift the post straight up. Also it's important to drive the bolt until it is snug unless you want to bend your lag screw.
I used a sawzall to cut the posts that had a jagged surface left.
If it hadn't just rained so much I think it would be a good idea to saturate these posts!
Here are the pics in the incorrect order
