How to remove hydraulic pump from 1952 Case VAC?
   / How to remove hydraulic pump from 1952 Case VAC? #11
Just how do you use a brush hog with out raising and lowering the unit.
Some finish mowers have 4 wheels and you simply pull it around, but a 2 bladed brush hog, perhaps you will tell us how you do it.
   / How to remove hydraulic pump from 1952 Case VAC? #12
pull mower man.
they been around.. drawbar pull.
tons o antiques didn't hav a 3pt lift.
when i bought my 5' KK hog years ago, you could assemble it as 3pt or DB pull/no lift.
   / How to remove hydraulic pump from 1952 Case VAC? #13
That may be true, but does he have one.
   / How to remove hydraulic pump from 1952 Case VAC? #14
he says he bought it to mow and pull a wagon.
we can only assune he has or is getting a pull mower.. or is torch/weld converting a 3pt'er to a pull style, and that he has a drawbar setup.
my vac has a drawbar/step plate aft and under the pto.. 1/2" plate..
http://www.tractorshed.com/gallery/uptest/a64388.jpg
   / How to remove hydraulic pump from 1952 Case VAC? #15
What I am saying is that it would probably be better to purchase a new pump and fix the hyd system than to acquire another bush-hog.
Just saying .
Just saw that you did not have a 3pt at all. so forget about the hyd.
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
UNUSED FUTURE FT-P680 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
UNUSED JCT HYD AUGER 8", 12" & 16" BITS (A58376)
UNUSED JCT HYD...
2002 International 9200i Truck (A56438)
2002 International...
John Deere HPXD (A57149)
John Deere HPXD...
