How to sharpen Brush mower Blades?
   / How to sharpen Brush mower Blades? #1
MrSteve
Platinum Member
Middleport, NY
John Deere 2025R
Ok I know it's a BIG lawn mower blade, but really what is the best way to sharpen brush mower blades? What should be used to sharpen the blade? Can you do a good job by leaving the blade on the mower? When do you know when they need to be sharpened? Can the blade be sharpen down to more of a "edge"? I understand the more of a edge you put on the blade that would make it that much closer to need sharpening or replaced.
I am asking the above because I would like to know if I can get a better cut from my brush mower. I have 11+ acres that has been mowed by a finish mower for 4+ years (by a riding mower, thank God that's over), so all my grass is clean from any "brush". I have used the "hog" to cut the grass last summer and it did "ok", just wondering if I can get it closer to a finish mower look. I guess one day I will get a nice 3pt finish mower, but for now the brush mower is all I have. ANY thought would be great to hear.
Mower is a 72" 3pt.
   / How to sharpen Brush mower Blades? #2
Hi Steve,
Hope you and the wife are enjoying your new tractor /forums/images/graemlins/grin.gif
OK, some will probablly cringe when I say this. I use my Dewalt 5" angle grinder to touch the blades up now and then. If they get really knicked up from the boulders growing out in the field I will change the blades. I use a Woods SQ-60 Squealer bush hog. Out in the field, if those blades are anywhere near sharp they do a good enough job for me. And when I hit another boulder I dont feel as bad /forums/images/graemlins/grin.gif If your trying to do some semi finish mowing with that implement, well then you might have to have blades in much better condition .
scotty
   / How to sharpen Brush mower Blades? #3
After the 2 years of hogging and finding most of the foreign objects I did the same thing. ( left the hog on the tractor and set it down on blocks ).Used a 4.5" hand grinder with a fine wheel and finished it with a cut-off wheel using the side of the wheel ( blade came to nice cutting edge. ) It will never be the same cut as a finish mower, but came out pretty good.
   / How to sharpen Brush mower Blades? #4
Same here, angle grinder.
   / How to sharpen Brush mower Blades? #5
DeWalt grinder.
I use it on my finish mower and bushhog blades.
I previously used a bench grinder.
I believe that I get much better (and faster) results with my little angle grinder.
Thanks to EVERYONE for your replies...
BB_TX... Sorry I should had done a search, I useally do, but I didn't in this case.
   / How to sharpen Brush mower Blades? #9
As others have said.. I use an angle grinder to sharpen my brushhog blades. I don't 'sharpen' them but rather take them down to a 3/32 or 1/16 edge for brush. However i have sharpened them like a lawnmower blade when i was just clipping black tops off the lawn and pasture... a easy hand ont he position control and you can do a pretty good lawn cut with a brush hog if you don't get in a hurry.
Soundguy
Well I guess I have some work to do... I don't think my blades have ever been 1/16", more like 3/16"... Maybe I better go see with a tape and not my eyes.
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2001 MACK RD688S ROLL OFF TRUCK (A51243)
2001 MACK RD688S...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2015 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2015 MACK ELITE LEU 633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
