How to you store the random oil jugs?
   / How to you store the random oil jugs? #32
Any details as to why he thought the oil caused the failure?
If engine blew, likely it was because it didn't have any oil in it.
15W-40 should work in any engine except in below freezing conditions and even then is should not "blow" an engine. It might cause some pre-mature wear at start up and make the engine a bit hard to turn over but nothing else.
   / How to you store the random oil jugs? #33
Has anyone had a problem with anything by using the wrong oil?
I did, with my '84 F150 which was the last new truck that I bought. I changed the oil religiously using Quaker State 10-30; by the time it turned 50K miles it sounded like a sewing machine going down the road. One day a lifter collapsed and it started knocking so hard that I pulled over, and made arrangements to have it towed home; after talking to my father I let it set a couple of hours and it sounded better so I drove it home.
I did some reading and found that QS is a paraffin based oil and was known to coat hydraulic lifters. I changed oil brands, dumped some Marvel Mystery oil in it, and ran it; over time the engine quieted down until one day I was in hilly country so I dropped it into 3rd and ran it hard to get the rest of the crud out of it. I put another 120K miles on it before selling the truck.
2019 John Deere 204L (A47477)
2019 John Deere...
2017 Hino 268 20ft Flatbed Dump Truck (A52377)
2017 Hino 268 20ft...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
