How to you store the random oil jugs?
   / How to you store the random oil jugs?
I've changed the drive oils once in just over 260hrs. I changed them at 50hrs and the fluid looked clean, no metallic sparkles, and I have just over 260hrs on it now; everything working(rear locker and front drive) as they should. Maybe I'll change them out this spring, if it ever arrives.
I’d change them now if I were you. Do engine oil/filter all at the same time and get them on the same schedule. My rear diff has shavings every time I change. Apparently that’s normal though.
I found my solution at Wal-Mart last night!
   / How to you store the random oil jugs? #23
After my painful experience with lots of little bottles, I started buying in 5 gallon buckets of oil and bought a "pail tipper" that made it easier to pour from the buckets. Now I use synthetic 0W40 for the tractors and one oil for the trucks, The only empty jug I keep is for measuring oil from the 5 gallon bucket.
   / How to you store the random oil jugs? #24
I try to buy in amounts equal to an oil change. If for some reason I want to get rid of a partial, it gets mixed with the bar and chain oil.
That cleared off a nice section of my workbench at least. I’m slowly switching everything over to Amsoil products, but it may take a while because seems like all the toys had their oil changed last fall.
I also “developed” this handy-dandy cheat sheet for all of my machines so I can quickly find out their maintenance schedule, oil type, amount, filter, tire pressure, etc, without having to flip through a half dozen different manual. Gonna hang this on the wall above my workbench.
   / How to you store the random oil jugs? #27
At one time, a few years back, there was talk that the diesel engine oils were harmful on gasoline specific catalytic converters. I personally have found no real evidence of that thru my research. I have a combined 240,000 miles on two Toyota Tacoma's and I run T6 in them with no negative results.
There is a new Rotella T6 product that claims it is designed for gas and diesel engines. I haven't seen any in my neck of the woods yet.
Your Tacos run 0-20 though right?
   / How to you store the random oil jugs? #28
Has anyone had a problem with anything by using the wrong oil?
   / How to you store the random oil jugs? #29
My buddy blew up a v10 ford and thinks the 15-40 oil he had in it was responsible
   / How to you store the random oil jugs? #30
Any details as to why he thought the oil caused the failure?
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Powder River Squeeze Chute (A55218)
Powder River...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
