How well would an infrared thermometer work for checking tires?
   / How well would an infrared thermometer work for checking tires? #11
Had a TPMS with temp on a 3 axle toy hauler and had one tire running 10 or so degrees hotter then the rest on the same side with all at the same pressure and ended up that it was coming apart iternally and saved me from a blowout. Used an IR thermometer on tires, bearing hubs and differentials while traveling with good results.
David
   / How well would an infrared thermometer work for checking tires? #12
Cupping is usually a combination of balance and shock absorber problems. Best advice would be to watch both front tires from another vehicle while going 55 --> 65 mph. If its a shock problem, your new tires will be cupping soon, too.
I have a FLIR brand IR camera attachment for my Android phone that's just wha flir_20160726T112055.jpgt you want to see tires with. $250. Works with the phone's optical camera and operating system. Plugs into the USB and power port.
   / How well would an infrared thermometer work for checking tires? #13
My TPMS for my TT & car trailer has a temp sensor along with the tire pressure. Nice things to know when on the road.
I have a FLIR brand IR camera attachment for my Android phone that's just whaView attachment 577389t you want to see tires with. $250. Works with the phone's optical camera and operating system. Plugs into the USB and power port.
That's why I asked about the thermometer; it will achieve the same goals as your Android for a lot less money. The purpose isn't to diagnose the problem; merely determine the front end is out before trashing $500 worth of tires. (Which I should have noticed before they got to that point.)
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2018 Ram 5500 4x4 Crew Cab Flatbed Utility Truck (A55973)
2018 Ram 5500 4x4...
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
