How would you repair this?
   / How would you repair this?
Dan they are steel, with a rubber pad glued to them.
   / How would you repair this? #22
So no metal to metal contact with the blade. Hmmm. The only thing that I can think of that would cause the blade to crack from the back is if it were nicked and had a stress riser, or if to were bent/creased at one spot.
A blade broke at work once, and we had no backups(guy was afraid to say he broke so many blades) so I tigged it back together to finish the job. Carefull inspection after the blade broke again in a different spot, revealed that the blade had many cracks all starting from the back.
We cleaned all the chips out of the wheels, and the top guard and blade life improved.
   / How would you repair this? #23
Shield Arc, I see what the problem is. You keep your saw too clean! Just kidding. Blade cracking is the way better quality blades usually die.
   / How would you repair this? #24
Mysfyt where do you buy your blades at? I have the hardest time finding them. I just bought a dozen Lenox blades. So far I'm not impressed!:thumbdown: This blade broke about a month ago, it started cracking at the top of the blade, not at the teeth!:confused:
Yes I used ER 312 stainless steel.
SA,
Try Superior Saw and Supply in Tacoma. They have the welding/grinding machine to fix broken blades and make new ones from coil stock. They also grind chipper knives. 253 572 7171, 2712 Pacific AV
Ron
Thanks Ron!:thumbsup: I can't say I ever heard of them. When working I always dealt with the Sharp Shop in Seattle. But that was mostly for chain saws, and demo saws.
   / How would you repair this? #26
SA,
Ron
Good to know... thanks Ron!
Oh yes, the world of bandsaw blades! Find yourself a good blade and then wait for the manufacturer to turn them into junk. Ive got over 30 years of experience of purchasing them, and quality comes and goes! Lennox used to be good blades, but I won't buy them anymore. Wikus,if you can find them in your
area are good right now. McMaster Carr blades have been good to me, but they get a bit pricey. And speaking of price, you get what you pay for.
The problem many companies often have with quality going downhill is the lack of understanding/desire to watch your tolerances and replacing or refurbishing tools to maintain the specs.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
Cushman Cart (A55853)
7ft Fork Extensions (A55851)
7ft Fork...
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
