Howse Dirt Scoop
/ Howse Dirt Scoop #1
John_Montoya
Alabama
Kubota L2000
I have a Kubota L2000 small tractor. I am considering the purchase of a dirt scoop so I can move piles of dirt and gravel. Do they work well for this?
/ Howse Dirt Scoop #2
I think that's what they were designed for. I'm not sure how big your tractor is, but they come in 24" and 30" widths, and some are reversible. Here's a link to a discussion from a few years back on the dirt scoop.
/ Howse Dirt Scoop #3
The rear scoops work quite well. They do not require fwd or power steering for adequate performance as does a front loader. As you load the scoop, your rear wheel traction increases. Limitations are: Capacity - about the same as a wheelbarrel, Lift height, and excessive compression loads on lower links. Stabilizer arms, which are standard on most newer tractors, reduce the problem of excessive compression loads. Lift height is not a problem if you are not loading a truck or trailer. While capacity is only that of a wheelbarrel, it is great to not need a shovel for loading or a strong back for transport.
/ Howse Dirt Scoop #4
They work a lot better if the open end faces the tractor when loading, although the stabilizer bars help reverse operation. They tend to ride up over the pile when you are backin' up. You may have trouble on uneven ground getting it high enough to continue movement, i. e. it'll stick your tractor if you're goin' uphill. /forums/images/graemlins/tongue.gif
/ Howse Dirt Scoop
I definitely want to reduce the shovel work I do. It takes too much time and effort. Since my tractor is not that big, I am thinking I should get a 24" instead of a 30" scoop. That way I won't have a tendency to overload it.
/ Howse Dirt Scoop #6
I used a KK 30" scoop and a yanmar 1700 to move many many yards of dirt when my house was being built. A 24" may have been more matched.. but the 30" worked fine when i added a couple hundred pounds to the front of the tractor.
Soundguy
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
296385 (A57192)
296385 (A57192)
2015 FORD F150 4X2 PICKUP TRUCK (A59908)
2015 FORD F150 4X2...
2016 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2016 Chevrolet...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2018 Land Rover 4WD SUV (A61569)
2018 Land Rover...
