snoracer
- Joined
- Oct 4, 2013
- Messages
- 11
- Location
- Northern, Mn
- Tractor
- John Deere 4300, Two John Deere 425's AWS, Allis Chalmers CA
You cannot believe how careful/clean you have to be with axial piston pumps & motors. The slippers in both have to ride on a thin film of pressurized oil on the wear plate to keep from scrubbing. The cylinder barrel and port plate mating surfaces are the same. You loose that microscopic film of oil and start metal to metal contact, and it's just a matter of time before it's toast again.
When those units are assembled, they'll be run on a test stand going through the different pressures etc, the end of the test there will be an oil sample taken while its running and do a particle count, to see if anything is breaking down (scrubbing). If the sample is within acceptable specs, the unit is passed on to assembly. If its not, its rejected, tore down, faulty parts replaced and back to test.
Gear type units are more tolerable to debris then the axial piston type. You can get the high pressures with the axial piston pumps/motors that you cannot get with any other style. But the main culprit in them is foreign particles.
If he's already up and running I wish him well, and would advise changing out the hyd filter a couple times just in case. If any debris has found it's way to the pump it's already too late.
Thanks for the reply - I will post part 4, re-assembly, a little later, but for now I'll tell you that I was very careful about cleanliness during re-assembly.
dfkrug stressed that same point when I spoke with him during this repair. I wish I could have found a factory assembled complete unit, but they just aren't available. I did remove the pump from the backing plate and also took the pressure relief vales and springs out of the backing plate, in order to look for any foreign debris. Non was found. The pump was in perfect shape. As you suggested, I did replace every part in the motor. The cylinder barrel and wear plate came as an assembly. It was wrapped in a sealed plastic wrapper and completely coated in oil. I replaced the suction screen and hydraulic filter as well. The tractor is up and running fine. I'll put some hours on it and then change fluid and filter again.
