/ HST vs Gear Transmission - which would you recommend on this tractor ?
#181
I dont like gear for loader work, hydro is much better, when I do loader work I have to shift 3-6 times to get a bucket full of dirt.
The way I look at if the front stays down when pulling a log then the tractor is not pulling to much, sometimes I think FEL work is harder on my tractor then hauling firewood, I know it is on my front tires. I fill my bucket up with dirt and it feels like I'm lifting a mountain.
I hauled some horacious twitches with my little L275 when learning to use it... two good sized, tree length maple with a couple of smaller trees was normal. Often I'd pull over a half cord with that little tractor, thrashing and tearing, dragging myself forward with the bucket when I couldn't get traction. I often had over a half cord of tree length hardwood on the winch, while the tractor only weighed about 3300 lbs including the loader and winch. It's really a marvel that I never broke anything. Yet I've never had a load on that the 3 pth couldn't. I would like t osee you come out of the woods with one of the loads on after the 3 pth needs an assist from your winch. :thumbsup:
Sometimes I like pointless discussions just to have a distraction from todays news. I know for a fact I can haul a HST M59 with back-hoe around in circles, all because gear tractors just have more traction and can push harder.........
I did a push test with my HST M59. With it pushing up hill in medium I couldn’t hardly reach the traction limits and spin out. I dropped to low and with it in 4x4 and the diff locked I was able to spin all 4 wheels. How would a geared machine push harder?
What a pointless discussion this turned into. The bottom line is in some applications geared is better while other situations the hydro is better. Since most people are only going to own one tractor they are going to compromise.
I love a manual for most things. My tractor is an HST. I feel that the HST is the best way to go for my use. So if your suggesting that my post above is calling out HST owners as girly men or something, your incorrect. Maybe I misread, and your not thinking of me or my post.
My point was that a manual, if used properly, is not a maintenance nightmare. And that an HST can wear, fail and cost huge money to bring back. Both can fail. Both can be considered a great choice.
Your L3400 weighs maybe 5000 pounds with loaded tires and a loader. The M59 weighs 8400 plus loaded tires and other accessories. You’re at a 2-1 disadvantage in weight and HP. There’s zero chance of you out pulling one even with the traction advantage of r1 tires. If you want to haul firewood I’m going to skip the dragging it a mile through the woods step and put it on my truck. If you want to load dirt I’ll have my yard bucket filled and dumped before you get done selecting a gear.
A geared machine would easily do that in Medium range in any of the 4 gears. Heck, it even might do it in 1st gear in High range.
You're very slowly getting to the point of Messicks video. Yes a HST will pull almost as much as a geared tractor but you have to drop it to low and it will still make a lot of noise and heat with very little work done. While the gear tractor will do it in Medium range or even High range.
I couldn't find a gif for kicking a hornet's nest so... :stirthepot:
So when the next newby comes along and asks which one should I buy, instead of pointing out the advantages of each transmission for the various jobs and trying to determine which sets of jobs he is trying to do and making the recommendation from there, we just now need to say "get a gear" because it puts more power to the ground without losing power to heat and noise" ? Gotcha.
I wonder why tractor manufactures make both gear and hydro tractors?.. Oh,..yeah hydros for weenies and ladies. Real men with big ones run gear machines. So if you don't want to be a weenie, then get a gear machine... gotcha.
A lot of you guys are about as scientific and objective as a rock.
In my "weenie" opinion if there weren't advantages in both hydro and gear machines they wouldn't make both. For the work I do, I have decided I need a hydro machine. I have owned both, and used both over the years, 2 gear 3 hydro. I have settled on the hydro for a reason. IT IS THE BEST, for the work I do. If it wasn't I would have a gear.
