RedNeckGeek
Super Member
- Joined
- Jan 1, 2011
- Messages
- 8,754
- Location
- Butte County & Orcutt, California
- Tractor
- Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
I am just going to assume you have cleared your land of all the trees and had your entire acreage paved to minimize the threat of wild fires. Between that and the fire sprinkler system you surely had installed in your house, you should be good to go.
FYI, 8 of the 13 acres here were cleared of brush in 2011 using a bulldozer and chainsaw. I kept the larger oaks, madrones, and ponderosa pines, in most cases removing the lower limbs to break the fire ladder. The 35 greyhound bus sized slash piles were burned the following winter. An erosion control mix of barley, rye, and red clover was planted in the dozed areas, and I keep it mowed until it dries out in the spring and stops growing. The 30' of landscaping around the house is composed of low fire energy plants and decomposed granite ground cover. The house itself is covered in a fire resistant stucco like product, and the roof is concrete tile. There are no roof vents, and the airflow into the attic is through screened openings at the eaves. In other words, the home was designed to be as fire resistant as possible. I don't have a sprinkler system in the house because the odds of fire starting inside the home are no higher than anywhere else in the country, and probably much lower as the home wasn't built until 2007 and met all current code requirements. Even with all that, I'm looking into a system that can autonomously spray fire retardant on the house and surroundings, even during a power outage. It won't be cheap, but it's had a very good track record during the many wildfires out here last year.
Last year on Labor Day, a fire started across the canyon from here, burned two homes and a mobile directly across from me, spotted across the river to this side, and burned several thousand more acres. I sat with two CalFire firemen in my driveway all night waiting for it to reach my property, but a rock outcropping below the house stopped it. The firefighters were quite confident that the fire safe space I'd created would have allowed them to save the house should it have come to that. The next morning all of the fire incident command personnel met in my driveway to asses the status of the still burning fire, and by noon were convinced enough that there was no longer a threat that the firemen and their pumper truck were redeployed to more urgent needs. Maybe I'm just whistling past the graveyard, but in my mind that was pretty concrete evidence that I had successfully identified the wildfire risks and that the associated mitigation strategies I'd implemented worked.
I hope you have as much success with Harvey. I've attempted to have a level headed dialog with you, but you insist on using hyperbole and exaggeration. In the future, I'd appreciate it if you kept your snarky comments to yourself, as they do nothing to strengthen your arguments and only waste time for both of us.:2cents:
