hyd cooler hoses bulging - normal?
   / hyd cooler hoses bulging - normal? #21
wow now this is funny, i just got my nh tc21da monday,
tuesday morning i go out to start it, and the two lines blew on the cooler, they come out and get it fixed, all was well, wed, morning i go out start it up, needing to move some snow, and right under the clutch pedal was a oil leak, another hose connection, i call the dealer and i was told that because of the cheap china hoses and the cold (the oil was thick) is why this is happening? so with only two hours of use, its had /needs two repairs...
   / hyd cooler hoses bulging - normal? #22
I don't know how much room you guys have where these hoses are. But, If there is enough room has anyone used a metal elbow with short piece of straight hose on each end. That might stop the problem from developing again.
   / hyd cooler hoses bulging - normal? #23
In essence, that's what the fix is from NH, except the new lines run back to the area of the filter.
the parts for the repair, $87
completed mission...still not sure where the "conduit" goes (which is actually a piece of plastic wire loom/cover). I had to remove and reseat the filter, since I must have broke the seal getting the bolt there off and had a small leak.
   / hyd cooler hoses bulging - normal? #26
It looks like the wire loom should go over the tubing that is closest to your battery (if it fits). Seems like it would protect it from the battery gases.
   / hyd cooler hoses bulging - normal? #27
That's right, it covers the tube where it is near the battery.
I never put mine on because I couldn't figure it out, until I visited the NH parts site and there it was. :)
I still haven't installed mine since I replaced the OEM battery and posts are now in front.
   / hyd cooler hoses bulging - normal? #28
My dealer does not seem to know about the kit that fixes the bulging hose problem.
If anyone knows the NH parts number please send an e-mail to cody.catAThotmail.com
Change AT to @
Or EVEN BETTER send me a private e-mail via the forum.
Many thanks.
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
2013 CAT 312EL Excavator (A59213)
2013 CAT 312EL...
PREVIEW DATES AND TIMES (A57453)
PREVIEW DATES AND...
2013 Yamaha YDREX4 Golf Cart (A56859)
2013 Yamaha YDREX4...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
