Hydraulic Cooler Unit Replacement
   / Hydraulic Cooler Unit Replacement #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
The Hydraulic Cooler Unit on my Kioti CK20 started leaking. This was detected because I smelled a strange odor and stopped to investigate.
I called TriCounty Supply, the Kioti Dealer in Western New York and they ordered a replacement unit under the warranty.
To replace this cooler took about 15 minutes. I filled the unit with hydraulic fluid prior to installing them. I think this helps to keep air out of the system but maybe it is not necessary. Capped off the fluid levels and good to go.
Well designed and easy to work on tractor and quick, friendly response from dealer. Can't ask for more.
   / Hydraulic Cooler Unit Replacement #2
Got any pictures, i'm not sure what your talking about. Just curious as I have a CK20 as well and don't recall seeing any cooler on mine.
Steve
   / Hydraulic Cooler Unit Replacement #3
Steve
It will be infront of the radiator and right behind the air cleaner.
It is only on the hst tractor.
It looks like a baby radiator.
   / Hydraulic Cooler Unit Replacement #4
Mine's a gear so I guess that is why I couldn't find it.
Steve
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
294 (A52706)
294 (A52706)
2019 KOMATSU PC490LC-11 EXCAVATOR (A60429)
2019 KOMATSU...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
