Hydraulic fluid frothing...
   / Hydraulic fluid frothing...
The saga nearly over and I can finally write the end of the story.
I looked in vain on Sunday (Saturday's are round-to-it days) and could not find the quick attach coupler. It appears as though most of the garden variety tractor/home supply stores do not carry JD hydraulic replacement parts. I think I know why but won't go there. /w3tcompact/icons/wink.gif
Located a JD dealer on the way to work and had to order a replacement ($14.35 - thank you very much!!). Oh my, look at the new tractors - drool, slobber, no, no - only parts Terry. /w3tcompact/icons/blush.gif/w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif So I got two, not going to loose anymore weekend tractor fun, err work time.
Fixed, done, first tractor casuality corrected. Now, I can get to the more serious work: rear lights, mount stuff/toolbox, hooks on FEL. /w3tcompact/icons/smile.gif
Terry
Damn... fixed the leak but the FEL still drops. /w3tcompact/icons/mad.gif
As mentioned, got the parts and connected the FEL. Tested it and no leaks. Woo-who!!!
So, I turned off the tractor and left the FEL about 21 inches off the ground to see if it would drop. Son of a female dog, it did. Dang thing dropped 3 inches in a half an hour.
Uttering many bad words - just like being in the Navy again!!
Suggestions?? Leave the color out!! /w3tcompact/icons/wink.gif
Terry
Latest update....
Talked to my JD dealer and he said that the with the engine turned off, the FEL, from a fully raised position, would be on the ground in 3 hrs. So, in his opine, it is normal. Done. Finis.
Terry
   / Hydraulic fluid frothing... #24
Terry,
My 4700 + 460 FEL will leak down as well. If I leave the bucket off the ground and turn off the engine. Eventually the bucket will be on the ground. T'ain't timed it but a couple hours seems about right.
I have a leak in one of my fitting in the Power Beyond Kit that only shows up when I have the backhoe attached. My dealer gave me the part that we think will fix the problem but I have yet to put it on. Some time soon....
Later...
Dan
dmccarty,
I do not have any other apparent leaks and just replace a faulty coupler. Sometimes you have to expend your energy in other areas and that's my plan.
Terry
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2011 PROCO 130BBL VACUUM TRAILER (A53843)
2011 PROCO 130BBL...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2025 SDLANCH DUMPER (A53843)
2025 SDLANCH...
2009 INTERNATIONAL PRO STAR+ (A53843)
2009 INTERNATIONAL...
30007 (A53424)
30007 (A53424)
