Hydraulic pump whine after valve installation?
/ Hydraulic pump whine after valve installation? #41
Have a few questions. are you trying to run the blower itself on the tractors hydraulic pump, or is it an added 3 point pump?
does the noise happen while the tractor is in motion or standing still.
thanks
my front blower runs thru 1" hoses for supply ans return.uses a 25 gallon reserve oil tank to help keep fluids cool during operation. i was told that a tractors hydraulic pump cannot power a blower by itself, as they dont have the pressure or volume to handle the units.
but im no expert...thats JJ's field
I have the factory front mount PTO with electric clutch. Blower is belt driven from the front of the engine.
/ Hydraulic pump whine after valve installation? #43
Gypsyman I'm glad to hear you got it sorted out.
I have a question - did your investigation indicate that the main, external hydraulic pump sends fluid through passages in the transmission case to provide fluid for the transmission internal pump? I had assumed the circuits were separate but after reading your description it seems they could be in series.
They both pull from the same strainer or cavity. According to the flow diagrams in the manual they are separate circuits.
/ Hydraulic pump whine after valve installation? #45
Anyway to extend the suction strainer so it stays under fluid level? I would think this would be better for all the components involved.
Unfortunately there isn't. Just a matter of training myself to wait 15-30 seconds before operating the hydraulics.
/ Hydraulic pump whine after valve installation? #47
I am still wondering if a couple qts extra oil would stop it all together? Glad its working to your satisfaction now! That is a neat rig glad I dont need one a snow blower that is! :D
Its not uncommon to add extra oil simply because every time you put an attachment on the system you may not get all the oil back depending on where the cyls happen to stop etc if you follow me.
I'm going to run it slighty high but the strainer is well above the level of the dipstick. Now that I know what it is I will just change my habits to match.
/ Hydraulic pump whine after valve installation? #49
Where did you get the ROPS ,and is that the HOYE turf tire set?
It's been a while but I believe the ROPS came from Hoye. It's a Custom Products of Litchfield folder.
I put the turf kit together with wheels from Hey Wheel built to my specs.
/ Hydraulic pump whine after valve installation? #51
Hadn't thought much about your turf wheels and tires till mentioned here. Are you confident in your front to rear ratio? Just looks like the size difference in the tires is not enough. Sure don't know, just asking. Any hint what Hey Wheel charges for those wheels?
The front to rear is working great. The picture is somewhat deceiving. Slips in and out of 4x4 on hard surfaces easily. Had a bugger of a time getting the right tires as the manufacturer specs listed on most sites was quite a ways off of actual once the tire were mounted.
I believe the wheels built to my spec were $450 from Hey Wheel. I have a local company that could have done them for $350 but they were too backed up for a small order at the time and I wanted to get them mounted.
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
(2) STAINLESS STEEL DOUBLE SINKS (A60432)
(2) STAINLESS...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
