Hydraulic squeals when lifting heavy load
   / Hydraulic squeals when lifting heavy load #21
Iv never had an issue with the Golden west universal tractor fluid though which is one of the brands TSC uses here. Any universal trans/hyd fluid should work well.
   / Hydraulic squeals when lifting heavy load #22
You guys have the current experience with various brands of fluid. However, I have to say I am a skeptic. I can see some equipment being designed for "low viscosity" or "high viscosity" hydraulic fluid having nothing to do with brands or "quality." I just doubt there is proven good versus bad among commercial hydraulic fluids that would cause one to produce squeal and the other no squeal. I predict that whatever it was that caused your squeal will be back regardless of what brand fluid you use.
There definitely is a difference, at least with the GC2410, at least with my GC2410...within days (or maybe hours) of using the TSC oil (claiming to be Permatran-III equivalent) the squeal occurred when loading the hydraulics and continued until the next fluid change 200 engine hours later. Over one year later, not a single squeal using the Mobilfluid.
   / Hydraulic squeals when lifting heavy load #23
Did the same thing years ago on an old JD, squealed like a banshee, trip to JD & HyGard fluid fixed it. There is a difference.
Ronnie
I unloaded 3-1000 lb+ bales last night and not a peep out of the hydraulics. The last time I unloaded some prior to the fluid change it was squealing horribly. No doubt in my mind that it was the TSC hydraulic fluid causing the problem.
   / Hydraulic squeals when lifting heavy load #25
We live & learn, i'm sure there are good alternatives to "brand" specific, after that one experience, i don't want to find out the hard way & always spend the $$$ for "brand" specific, even though it's a big OUCH.
Ronnie
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2016 Troy-Bilt 21in Push Mower (A55973)
2016 Troy-Bilt...
3PT SUBSOILER (A52708)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
John Deere 5105M (A53317)
John Deere 5105M...
