Hydraulic top link use and limitations
   / Hydraulic top link use and limitations #11
jinman
Thanks for the heads up.
But I don't have any attachments that can rotate forward like that, plus I have removed the PTO shield as it is a worthless piece that has no useful benefit.
   / Hydraulic top link use and limitations #12
There's a nut on each side of what I think is the check valve (where the two hoses attach to the cylinder). Are they pressed to a 37 JIC type of connection or could it possibly be a pipe type connection and in need of re-sealment? I see no evidence of tape or caulk at either nut.
Loosen the nuts that are on the tubing on either side of the check valve, twist the valve 90* and tighten the nuts. You should be all set, there should be no sealant at those points.
On our New Hollands, the way Nickel Plate has his hoses routed with a loop is the best. You DO NOT want to turn that DPOCV downward. See photo:
If you ever get an implement that is prone to rotating forward and over-center, it could smash your DPOCV and hose connections into the PTO shield. This is the voice of experience speaking. I've had two implements that will rotate the toplink over-center and down when the toplink is fully retracted (shortest length). My PTO shield is bent downward where the HTL hit it. If the hoses had been downward, it would have been a disaster instead of something I fixed by pulling the pin and backing up the tractor. I have one boxblade and one middle buster that I have to remember not to shorten the HTL to its minimum length. If your HTL is more than 19.5" retracted, you don't have to worry, but if it is 18" or 18.5" you have to be careful. I know lots of different tractors have different geometry, but I'm just saying on our particular model, it's important to loop the hoses as Nickel Plate did and keep that DPOCV pointed upwards.
BTW: You cannot use your HTL with a post-hole auger. The auger hooks directly to the toplink bracket on the tractor and you have to remove the HTL when digging post holes. It's a snap to remove and disconnect the hoses, so its an easy job, but you asked about limitations and that is one I know of.
Excellent, thanks Jinman, I don't have a box blade, yet lol, but the idea of the equipment coming up and hitting the ports is a warning that I will heed.
I am 18.5" centre to centre with an 8.5" stroke so careful I will try to be, problems with the memory these days, go figure.
   / Hydraulic top link use and limitations #14
Mine is 19" to 29" from Fit Rite Hydraulics. So far I haven't found any interferance problems. On each new set up I try to check all the range of motions before I go to work. I don't have a DPOCV to deal with on mine. Some might consider that a safety issue but I don't see a rear impliment as being any different than a FEL and they don't have DPOCVs. And I have no trouble holding adjustment w/o the DPOCV.
I've just started using my new TnT and find it has enhanced the usefullness of my impliments greatly.
   / Hydraulic top link use and limitations #15
Gordon, after a few more hours of "TnT" use, you will be wondering how you ever got by without them. :laughing: It is amazing how few people actually even know about top and tilt hydraulics and they are perfectly happy with their manual adjustments. But once they learn about them and especially if they have the opportunity to use them on some other tractor, most people then want them for their own machine. :cool: :thumbsup:
I see it and like it, lol. My wish list grows.:laughing:
   / Hydraulic top link use and limitations #17
I can attest to the interference issue. when I first installed my HTL. I was so excited, didn't even think there could be trouble. I proceeded to lift the 3 pt all the way and actually watched it get crushed :ashamed:
I ordered new tubes and nuts but was able to straighten the bent ones and have had no trouble since.
I fooled around with the lines going different ways and settled for this setup (in 2nd picture), no problems in over 2 years now. even with rear snow blade riding up high on snow banks etc.
I like Beenthere's though and may look into some 90's
Before and after pics.
JB.
What about a hydraulic banjo or swivel attachments? I looked at Princess Auto and could not find them but this seemed a solution to the hoses coming straight out from the tube.
   / Hydraulic top link use and limitations #19
I couldn't operate my boxblade without it....or the landscape rake.....or the road grader....I guess I could get along without it on the mower...but why?
   / Hydraulic top link use and limitations #20
JB4310,
It appears that we have the same cylinder and I see that you flipped the whole DPOCV. I also thought about doing that but not quite brave enough. Was it a painless modification?
MASSEY FERUSON 204 ALL TERRAIN FORKLIFT (A52708)
MASSEY FERUSON 204...
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
