Hydraulic Tube Flaring
   / Hydraulic Tube Flaring #11
ProTools Direct Ridgid #377 Flare Tool $94.91, and is used for 37 degree flare fittings. Amazingly, there was a used #377 that recently sold on Ebay for $127!
The Ridgid bender for hardened tubing is the Ridgid #406, which runs $53.55 at that site.
What is the type of tubing and your source?
   / Hydraulic Tube Flaring #12
I've seen lots of 'alternate' plumbing for hyds.. especially on older tractors. For instance.. on the old ford N's ( 1939 - 1952 ). there was a hyd test port in the rear diff... ( the hyd pump was in the bottom of the diff ).. and you could chain your lift arms down, and tap into this port.. and get hyd pressure there when you moved your three point controll.
I've seen iron plunbing, and cast. Even saw a hose style sphighot valve... plumbed into one of those circuits... that blew my mind.. was old and still in operation... I was simply amazed.
Course the N's hyd system was 1500 - 1700 psi at 2.9 gpm.. when NEW.... subtract for wear and tear.. etc..
Soundguy
199049 (A51243)
199049 (A51243)
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
Curt Receiver Hitch (A51573)
Curt Receiver...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
