Hydraulic Tube Flaring
   / Hydraulic Tube Flaring #11
ProTools Direct Ridgid #377 Flare Tool $94.91, and is used for 37 degree flare fittings. Amazingly, there was a used #377 that recently sold on Ebay for $127!
The Ridgid bender for hardened tubing is the Ridgid #406, which runs $53.55 at that site.
What is the type of tubing and your source?
   / Hydraulic Tube Flaring #12
I've seen lots of 'alternate' plumbing for hyds.. especially on older tractors. For instance.. on the old ford N's ( 1939 - 1952 ). there was a hyd test port in the rear diff... ( the hyd pump was in the bottom of the diff ).. and you could chain your lift arms down, and tap into this port.. and get hyd pressure there when you moved your three point controll.
I've seen iron plunbing, and cast. Even saw a hose style sphighot valve... plumbed into one of those circuits... that blew my mind.. was old and still in operation... I was simply amazed.
Course the N's hyd system was 1500 - 1700 psi at 2.9 gpm.. when NEW.... subtract for wear and tear.. etc..
Soundguy
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2016 TAKEUCHI TB290 EXCAVATOR (A51246)
2016 TAKEUCHI...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
