Hydraulic tubing question
   / Hydraulic tubing question #22
I wish I could get 2 TRACTORS like Henro /forums/images/graemlins/grin.gif
   / Hydraulic tubing question #23
</font><font color="blue" class="small">( That is a monster, not to mention all the work port hoses you will have to deal with.)</font>
Quite true. But a fact of life if you need a number of valves.
Another approach is to locate the valves elsewhere and situate
cable linked levers for operator access. This setup is common
with full cab tractors.
   / Hydraulic tubing question #24
</font><font color="blue" class="small">( The compression fittings, swagelock, are very easy to install and come in a plethora of styles. Be sitting down when you price them out. )</font>
The actual flare fittings are rather inexpensive, typically totaling under $2 for
both flare nut and collar. A JIC37 flaring tool will cost you $50-200.
and is identical in principle to the $10 tools which produce a SAE45 flare.
Tube benders are also expensive from established manufacturers but can
be found in knock-off form by HF and others for $4-6 per discrete
tube size.
Note flare-less JIC37 fittings do exist which require neither an end flare
nor cutting the tube to precise length. These are however about 5X the
cost of vanilla JIC connectors.
New Holland WorkMaster 37 (A53317)
New Holland...
6-Band Wooden Barrel (A55853)
6-Band Wooden...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A57024)
1992 Talbert 70...
