hydraulics dont pick up
   / hydraulics dont pick up #11
if diesel eats the seal.. it needed replacing. seals should be petroleum proof.. oil is petro based.
I like to flush 'wet' sumps with a mix of diesel, some atf, and 91% rubbing alcohol.
soundguy
   / hydraulics dont pick up #12
have u tryied adjusting the flow control on the side of the rear axle i have seen them get screwed in or all the way out which does allow the oil to flow at the right rate
havent tried the flow control where would be located. putting it that way with the diesel makes sense about the seals may try that when i can get back down there thanks for yalls input hope on day can return the favor will keep posted
   / hydraulics dont pick up #14
the flow control valve should be on the rear axle housing on the right side by the heel of your foot
I will check it out for sure
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Chemical Containers Tank (A57148)
Chemical...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
