SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,524
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
How hard do you think it is? Unlikely it is above Grade 8, which is easily cut with a common good quality hacksaw blade- threaded or not. Just how inept do you think the TBN crowd is anyway.And how much time, hacksaw blades, grinding wheels etc. do you think it would take to "let users take a little off" of a hardened steel threaded rod? And did I mention that it is threaded.....what if, in the cutting off process you messed up the threads adding more aggrevation to the "custom" process. Unless you have your own machine shop I think paying for an "extra" set of longer threaded rods is reasonable.
BTW, I plan on getting one of these but I DO have the "quick hitch" and need about 31-33" of length. Guess I have a few more weeks to wait.
To the HYDRAULINK rep......my admiration to your poise and restraint.
Rob![]()
And yould be able to cut it to the exact length you wanted after experimenting with it awhile, rather than have a standard one that works, but you need to run almost fully extended for all your uses. I cant see any reason to have to buy a short one and a long one if you only need the long one. You can apparently. Go for it.
larry
