HydrauLink- a self-contained air over hydraulic top link
   / HydrauLink- a self-contained air over hydraulic top link #301
Kudos to the Hydraulink people for maintaining decorum...I've never seen such abuse heaped on any vendor here, particularly one with such a well thought out product..
And, every time I walk into the hardware store, which is quite often, the longer bolts cost more than the shorter ones, and no one gives the owner crap about it, or tries to get them for nothing! LOL
Wow! Way off target.
larry
   / HydrauLink- a self-contained air over hydraulic top link #302
I don't get it. How do I use your product to change the angle of an attachment when I want to shorten the link against the weight of the attachment?
I want to make sure I understand your question. Are you asking how to adjust it?
   / HydrauLink- a self-contained air over hydraulic top link #304
Agreed :thumbsup:
   / HydrauLink- a self-contained air over hydraulic top link #305
You have to drop the back of the implement against something and use it's weight as the front of the implement drops, or drop the implement and back the tractor up against it to get the top link to collapse. You can not lift with this product like you can with a true hydraulic top link. It's essentially an adjustable length shock absorber. An outside force has to be used to extend or collapse this top link.
If you go to our website at Demonstration video you'll see a short video entitled 'Adjusting HydrauLink' . That should demonstrate what it takes... it's easy.
   / HydrauLink- a self-contained air over hydraulic top link #307
What is the sku at Tractor Supply? I asked about it at the local store and they did not know anything about it.
Let me find out for you. It may require that we call someone that won't be in the office until Monday. Sorry for the delay.
I just got this sku for TSC from our distributor... Try 1018479
FYI... I was also just told that the product will be arriving in select stores on Monday.
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
