Hydro-Fracking an artesian well (worked for me)
   / Hydro-Fracking an artesian well (worked for me) #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
This is for anyone who might have a not so productive artesian well. Our well is 565 feet deep. It was drilled in 1975. The last few years (about 10 actually) it has had problems like running out of water. A month ago we had it hydro-fracked. This is where a well company inserts an expandable bladder into your well just below the casing depth and seals off the well. They then pump 2000 gallons of water into your well using a high pressure pump capable of producing 3000 psi of pressure. This is supposed to blow open any water veins in the well that may have blocked off over the years or open veins that may be partialy plugged. The highest reading I saw on the pump was up around 600 psi. It then slowly dropped off to around 250 psi until the water ran out from the tanker truck. I can honestly say that this procedure worked for us. We now have more water than ever before. We used to be able to do only 3 loads of laundry and take two showers in a day before the well ran dry. The next day would be showers only as the well would need two days to fully recover. So far we have been able to run the water for over 3 hours straight and still have plenty of water pressure. I've tried this several times by just letting a water hose at basement level run full wide open for a max of 3 hours. I keep trying to get the wife to run off about 5 loads of laundry. She refuses to do that much at one time. I can't say that I blame her on doing that amount of laundry in a day. The price was $2K with a guaranty that they will come back one more time if it doesn't provide you with more water than before. It took over a week for the water to clear itself of dirt, actually closer to ten days. I have a filter system at the tank that filled up a few times with dirt after having this procedure done. We could have had a new well dug. The cost would have been well over $5k with the tying in to the lines and eveything to the house. I feel this was money "well" spent.
   / Hydro-Fracking an artesian well (worked for me) #2
I have heard of the practice, but have never known anyone that has had it done. Sounds like a sort of back flushing of the well. Did you have to sanitize the well afterward? That is the part that I hate. It is like showering with Clorox for weeks afterward.
Dusty
Dusty
I asked if we needed to add anything to the well. The well company said it was not neccessary to add anything to the well for that purpose. They said the water they use to put in the well is clean. We didn't drink or use the water for cooking for two weeks afterwards just in case. I know it didn't smell bad.
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
