TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,084
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
When you are in a real touchy situation... like side of a hill next to a fence and some compromised traction mixed in, you really need full simultaneous control of brakes and wheel torque from zero to give you the best chance. An hst with proper ergonomic setup can present you all the advantage options. - - The second sentence in the quote tells me you havnt used your tractor enuf in demanding and unpredictable circumstances to force you to discover the advantage offered by a well integrated system in contrast to one that just makes the wheels turn. The problem that those who "dont ever need them" will find when they do, is a delayed or absent recognition of the need and a lack of practice in application. Now combine that with a control setup that makes the necessary contol action very difficult ....:tractor:
larry
I hope I misunderstood this post as it sounds as though you believe that I am either stupid, inexperienced or both with maybe a little na?et thrown in.
I grew up on a farm and have driven a tractor for over fifty years. I have used 2WD as well as 4WD, geared and HST. I have operated equipment in conditions as you describe and I prefer diff lock as opposed to split brakes as this works better for my tractors. Having used split brakes most of my life farming, it was kind of hard to adjust to the limited utility on my newer tractors and it took quite a while to adapt. If split brakes work better for you and your tractor then fine, but don稚 assume that I don稚 is the result of inexperience or ignorance.
At my age the é›»emanding and unpredictable situations no longer apply as I have learned enough not to get myself or equipment into such a situation. I also know that in an ç*¥npredictable situation, I am going to react instinctively and since seven of the tractors I operate have right foot brakes, that is where I am going to put my foot.
