Hydrostatic Drive and Independent Rear Braking
   / Hydrostatic Drive and Independent Rear Braking #11
I found that with the blower up, the front gets MIGHTY light, I also found the same problem with the brakes/hydro treadle as you did.. Using the cruise for right turns is fine, for left turns I use my toe on the brake, my heel on the HST...
I have it in my mind to build some sort of levers that will clamp to the brake pedal arms, like a dozer..
   / Hydrostatic Drive and Independent Rear Braking #12
"I have it in my mind to build some sort of levers that will clamp to the brake pedal arms, like a dozer.."
Or...you could trade it for a John Deere! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Hydrostatic Drive and Independent Rear Braking #13
Why would I want to do that? If I wanted an inferior machine with a higher price just for the logo on the hood, I would have bought a Kubota! :)
   / Hydrostatic Drive and Independent Rear Braking #14
Deere. I have a 655 (discontinued, {dumb idea}) that I would like to replace. No manufacturer to date has addressed the independent brake, treadle pedal issue in smaller compacts. Deere has been consistent with 'Side by Side' hydro control pedals on one side and independent brakes on the other. My ergonomics support that configuration.
   / Hydrostatic Drive and Independent Rear Braking #15
Cute logo on the hood: $500 ?
Money-like green color: $1500 ?
Having brake pedals on one side of the tractor and the hydro pedals on the other when the front wheels lose steering traction: Priceless! :)
- Rick
   / Hydrostatic Drive and Independent Rear Braking #16
Works well. Steers tractor and Howard P50 rotortiller (more tiller than tractor should handle) well with FWD engaged. Does not require operator to have three legs. Two on the right and one on the left. I am not opposed to BLUE. They have had the benefit of two other manufacturers designs preceeding them, and still come up short.
CHEAP - ???
Nonfunctional ergonomics - PRICELESS
   / Hydrostatic Drive and Independent Rear Braking #17
The larger New Hollands have the brake on the left side as well.. It never was a problem for me, since my boots are large enough to work both at the same time.
   / Hydrostatic Drive and Independent Rear Braking #18
I thought the Boomers had the two pedal design like the Deeres? I thought that was what the brochure showed, anyway. /forums/images/graemlins/confused.gif
   / Hydrostatic Drive and Independent Rear Braking #19
Class III Boomers are like that. The smaller units are treadle style.
   / Hydrostatic Drive and Independent Rear Braking #20
Sorry to butt in. I have a bota, and it works well with the cruse control. In the case of the 3130 the cruse only cancles if both breaks are pushed at the same time. Are you guys sure that yours are not set up the same way?
Just an idea.
Dane
PALLET OF (20) HUNTER CEILING FANS (A58376)
PALLET OF (20)...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
Quick Attach Stump Grinder Mini Skid (A56436)
Quick Attach Stump...
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
40' CONTAINER (A58376)
Pickup Instructions (A55272)
Pickup...
