hydrostatic trans - less pedal pressure = more power?
   / hydrostatic trans - less pedal pressure = more power? #11
The way I understand my JD is that the go pedal increases or decreases the volume of the hydraulic pump (or motor, whatever) and thus does increase or decrease the torque .....in a ratio opposite the resulting speed...
   / hydrostatic trans - less pedal pressure = more power? #12
A very common mistake by new operators is to push the pedal further when digging or climbing a hill only to find out the engine bogs down and/or stalls-then they come here asking if their machine is broken:D
:confused3:......I've been guilty of this (when brain kicks into neutral).....but I wouldn't ask here about my broken tractor (or wouldn't admit to it)....:laughing:
   / hydrostatic trans - less pedal pressure = more power? #13
The way I understand my JD is that the go pedal increases or decreases the the torque .....in a ratio opposite the resulting speed...
Pretty much the case.
   / hydrostatic trans - less pedal pressure = more power? #14
Yes the go pedal does change the volume of hydraulic pump. This increases the input torque required to drive it. I.e. makes the diesel engine work harder.
Since the hydraulic motor displacement is not changing it does not change the torque output of the motor just the RPM of the motor.
Roy
   / hydrostatic trans - less pedal pressure = more power? #15
And then you buy a new Kubota GL40 with the auto throttle that turns the HST pedal back into a 'gas' pedal.
40ft 10-Door Shipping Container (A55851)
40ft 10-Door...
2021 John Deere 8RT 370 Track Tractor (A53485)
2021 John Deere...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2008 Ford Ambulance (A47477)
2008 Ford...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
