hydrostatic trans - less pedal pressure = more power?
   / hydrostatic trans - less pedal pressure = more power? #11
The way I understand my JD is that the go pedal increases or decreases the volume of the hydraulic pump (or motor, whatever) and thus does increase or decrease the torque .....in a ratio opposite the resulting speed...
   / hydrostatic trans - less pedal pressure = more power? #12
A very common mistake by new operators is to push the pedal further when digging or climbing a hill only to find out the engine bogs down and/or stalls-then they come here asking if their machine is broken:D
:confused3:......I've been guilty of this (when brain kicks into neutral).....but I wouldn't ask here about my broken tractor (or wouldn't admit to it)....:laughing:
   / hydrostatic trans - less pedal pressure = more power? #13
The way I understand my JD is that the go pedal increases or decreases the the torque .....in a ratio opposite the resulting speed...
Pretty much the case.
   / hydrostatic trans - less pedal pressure = more power? #14
Yes the go pedal does change the volume of hydraulic pump. This increases the input torque required to drive it. I.e. makes the diesel engine work harder.
Since the hydraulic motor displacement is not changing it does not change the torque output of the motor just the RPM of the motor.
Roy
   / hydrostatic trans - less pedal pressure = more power? #15
And then you buy a new Kubota GL40 with the auto throttle that turns the HST pedal back into a 'gas' pedal.
2012 Dodge Grand Caravan SXT Van (A55853)
2012 Dodge Grand...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Cat TH407C Telehandler (A53472)
Cat TH407C...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
