I cry Uncle. I need help.
   / I cry Uncle. I need help. #11
Once you get that snap ring out, the bearing will probably need to be pressed out and the new one pressed back in.
   / I cry Uncle. I need help. #12
I just rebuilt the mower for my dad's 314. It uses the same hubs in the mower. Remove the snap ring with a screwdriver(s). Press or drive out the shaft with hammer and drift. Drive out the old bearings there's a spacer between the bearings. Clean up the hub, reinstall the new bottom bearing and snap ring. Install the shaft and the spacer. Fill the hup 75% full of grease then install the top bearing and pulley....voila.
I did get the ring out. I started making progress when a friend showed up for the town Easter egg hunt. That third hand really makes a difference.
Mighty Dodge said:
I just rebuilt the mower for my dad's 314...
You forgot to mention the second snap ring inside the hub. I beat on that poor bearing with everything I had before I figured out that second snap ring.
   / I cry Uncle. I need help. #14
Sandlot has the ticket!
Soundguy
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
