EddieWalker
Epic Contributor
There are several ways to get through the rock in a horizontal bore. The best and most expensive would be to hire it out to a guy with a bore machine that does line bores. I doubt you could rent such a machine. I had a hundred foot bore done under the highway in front of my place. It was 8 inches wide and cost me $3,000. They also sleeved it with an 8 inch metal pipe that I provided for that price. This was through clay and not rock, so the price is probably meaningless. You also don't need anything more than an inch in diamater anyway.
My next thought is to how do the miners, especially hundreds of years ago, drill holes into rock. Hitting a rod with a hammer over and over again doesn't sound practical, but I wonder if you could drill it with a masonary bit? Get a one ince bit and find a way to attach lengths of rods to it as you get further and further in. Getting the debri out of the hole will be a challange and would require pulling the bit out all the time, but I don't see why it wouldn't work with enough time. Keeping it straight would be the real trick.
If the drill wasn't strong enough, especially with ten or twenty feet of rod or pipe attached to it, maybe using an impact wrench to turn it would work.
I'm just guesing here and throwing out ideas. If it was me, I like the idea of trenching down ten feet and using the siphon as low as possible. I just wonder how you keep from filling in the well hole as you dig around it. Do you put a sleeve in there first? Then dig to the sleeve?
This is turing into one of those very interesting threads that I love so much about this site.
Eddie
Eddie
