I knew it!
   / I knew it! #11
Soundguy said:
A retaining nut. I guess a jamb nut might be more applicable in this setup.
Soundguy
I always thought a palnut was one of those little tophats...
   / I knew it! #12
two things..
1) will someone PM me about what I missed? I need a good laugh today.
2) I would use the Blue Loctite. NOt KNowing if you want this to be permanent or not.... Red is considered the permanent loctite. VERY hard to get apart. We use Blue Loctite in our Backhoe mount kits.
   / I knew it! #13
Yes.. I think those qualify, as well as many other kinds of 'push' nuts. I've seen them used as retainers and whatnot.. but after thinking about his application.. a jambnut would be superior.. etc.
soundguy
   / I knew it!
Personally, I would just use two of the internally threaded friction based fastening devices on each side, tightening the outermost against the innermost to prevent either from turning. You could also put a simple split or star type lock washer between the members of each pair. The internally threaded friction based fastening devices are tightened with a device known as a wrench.
   / I knew it! #15
Why buy a locknut to add to the regular nut.. when a jambnut will be cheaper and accomplish the same thing? ( 2 nuts tightened slightly against each other... ) Heck.. add a drop of the green loctite afterwards... kill the vibration problems..
Soundguy
2017 NRG BLENDER (A55745)
2017 NRG BLENDER...
2023 New Holland TS6.140 T4B MFWD Tractor (A53485)
2023 New Holland...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
