I need a bigger 'you know what'
   / I need a bigger 'you know what' #21
Re: I need a bigger \'you know what\'
pic 2
   / I need a bigger 'you know what' #22
Last pic
YES
Now, that 's what I'm talking about !
   / I need a bigger 'you know what' #24
After looking at some of the pics here, have your you tried to slide your bucket under one side/end, curling it (which should have more power available, and then hooking a chain around the rest and backing it where it needs to go?
It might gouge, but might be your only way to do it with your existing tools.
Sorry if this is redundant to what you have tried..........
Best wishes,
Ron
   / I need a bigger 'you know what' #25
Me thinks it should called "Carrymost"? or "Carry-not-to-heavy", but definitely not "Carryall"...
No, I have'nt tried that. Sounds like an idea /forums/images/graemlins/smirk.gif
   / I need a bigger 'you know what' #27
Jerry,
I think NOW would be the perfect time to approach the wife about the bigger "you know what." /forums/images/graemlins/laugh.gif
Don
   / I need a bigger 'you know what' #28
If Jerry is looking for support from TBN members, I’ll add my vote 'for you know what'. /forums/images/graemlins/grin.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif
   / I need a bigger 'you know what' #29
I can't take credit for my idea--I saw a Michigan front end loader LIFT the front of a FULL, HEAVY semi trailer that had broken through the ashphalt and was resting on it's 5th wheel plate, which was right on the ground!
The loader bucket was wider than the front of the trailer, but he had to slide under it, curl to raise it, then block the trailer to get a new bite. Took about 15 minutes, but he got the trailer to the right height! This was 20 YRs ago--saw the driver slip the loader guy a $100 and they both were happy! Had he needed a wrecker, I'm sure the bill would have been higher; plus this was in small town America (North Dakota IIRC). Fortunately for us (I was the assist driver), the pipe line crew was overniting where we were and was able to help us.
If you are able to accomplish this, you might be able to slip a couple strips of plywood under the rock to save the turf on the way to the final resting spot.
Best wishes,
Ron
No good.
Curling the bucket just lifts the rear of the tractor off the ground. (with 600lbs of fluid in the tires)
I guess I'll just wait till I can get ahold of the contractor.
   / I need a bigger 'you know what' #31
Hey you did what you could do------- short of getting a bigger unit!
Best wishes,
Ron
   / I need a bigger 'you know what' #32
Jerry, if you need to roll that rock onto something like plywood to use as a skid, you can use the lever method I've shown in the attached illustration. By wrapping a chain around the rock as shown and pulling in the direction of the arrow, the block provides additional leverage to roll the rock. The bigger the block, the more leverage you have. ...just another idea.
   / I need a bigger 'you know what' #33
Here is a picture of a slightly stronger carryall. If you reinforce your existing carryall as Gary_In_Indiana suggested and put tabs on in the nature of this one for the cat1 pins, it should carry most anything your tractor will lift. I know I've had my little Yanmar so loaded that I had to drive it with the brakes. /forums/images/graemlins/wink.gif
   / I need a bigger 'you know what' #34
another angle
   / I need a bigger 'you know what' #35
the manufacturer info
JIm, thanks for the idea. I'm sure it will work.
Jeff, my local tractor yard has those in stock. It did'nt look much heavier to me. Does the round tubing add the extra strength?
   / I need a bigger 'you know what' #37
Jerry, sorry that your carryall didn't carry all /forums/images/graemlins/confused.gif. However, numerous members have suggested good solutions. Buy a bigger tractor (always a good idea), have the contractor move it, beef up your current carryall, etc.
On the other hand, I too considered purchasing a carryall a few months ago and just wasn't happy with what was available. So, I purchased some 2X4X1/4" tubing and built my own. It's overkill for my BX2200, but I seem to always error on the side of "more is better"...in other words, if angle iron is good then 2X4 Rectangular tubing would be more better /forums/images/graemlins/grin.gif
Here is a link to a web page with numerous projects I've tackled. Might give you some ideas.
http://community.webshots.com/scripts/editPhotos.fcgi?action=viewall&albumID=64671033
DW
   / I need a bigger 'you know what' #38
Danny,
No one can access your photos. You posted the link to edit them, we aren't allowed to do that /forums/images/graemlins/grin.gif.
Jerry
   / I need a bigger 'you know what' #39
figured out the link and here it is....... web page
   / I need a bigger 'you know what' #40
Yep, Now that's a "carry-all" /forums/images/graemlins/grin.gif
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
LOT LOCATIONS (A59904)
Bobcat T590 (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Deere 35G (A53317)
2019 Deere 35G...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
