I Need Advice on a 5th Wheel to Gooseneck Adaptation
   / I Need Advice on a 5th Wheel to Gooseneck Adaptation #31
Follow up to my getting a new trailer. What's the switch on the left in this picture. The right switch is the water heater, but I can't figure out what the left switch is for.
It is for the electric heating element, if it is installed. Be sure there is water in the tank before you turn on the switches :eek:
Oh. Of course.
I'm so far behind the times I didn't even think of an electric element in an RV water heater.
Thanks.
   / I Need Advice on a 5th Wheel to Gooseneck Adaptation #33
I was going to say same; electric water heater. Mine only has the elctric switch; for gas you have to start pilot light and set temp control from outside.
electric is nice, and fast on those small tanks.
I drain and flush my water heater yearly. Got a hose adapter at the RV place, to reach up in the drain hole, and jet blast the depsoits in there. I clean up the gas vents etc at same time. I usually do that at same time as repacking the bearings(my axle manual says 12 months or 12,000 miles, whih ever somes first). The brakes get checked and adjusted then too. I bleach the fresh water system yearly too(in my manual).
Oh. Of course.
Thanks.
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
2023 Load Trailer (A55787)
2023 Load Trailer...
2013 Cheverolet Impala 1FL Sedan (A55853)
2013 Cheverolet...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
John Deere 7130 (A53314)
John Deere 7130...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
