I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor
That fits in there pretty nice, looks really good. Did you have to make that manifold hieght extension?
Yes the extension is 35mm ID and 1/8" wall, hoping it takes the heat. I will build more support in later. While the turbo looks heavy it is lighter than the original muffler it replaced that had zero support other than the manifold. I truly wanted the turbo to bolt directly to the exhaust manifold but then the oil drain would have to go down to the oil pan. Remember I didn't want to hack the pan and couldn't uncover the factory oil drain for this block which I believe is the dipstick tube access (although covered by the tractor frame rail). Turbo flange is different bolt pattern than the exhaust manifold also. I suspect the Bobcat manifold is a spendy unit. Another problem I encountered is the fuel tank shield, I couldn't sneak the turbo in under it without modifying it, also the reason I went with a pedestal mount. My air intake pipe is mounted very rigidly and the short intake connector will act as more support and hopefully vibration protection.
I used the valve cover for the drain, it is a very short run and the VW TDI turbo drain hose I hacked up (used part I had) looks like it will work ok, red hose is Gates multi-use hose. I use it for transmission line and fuel line in some applications. It should take the heat and petroleum product hopefully. This turbo should pass a small oil amount compared to a larger unit. Not too worried about the heat in the valve cover or oil drain there is plenty of windage space for the oil drain, also a nicely engineered baffle under the valve cover.
Sorry if I didn't answer any pertinent questions, busy day yesterday then company arrived and out came the beer. 10 inches snow here this morning looks like the hand shovel comes out :(
Fred, back on this today hoping to get a test run out of it with a temporary straight pipe until I find a nicely built short and 304 stainless glasspack so I can fab a sweet little quiet exhaust package. While I liked much noise in my younger days quiet is much nicer nowadays. Every now and again at work a Harley will drive by with bone stock pipes and sounds oh so sweet, usually driven by women.
   / I Still Hate My Tractor #362
Hi Fred;
Just found this thread, quite entertaining so I posted to encourage & receive the latest posts.
I installed a turbo on my Ford 1720 a couple years ago & couldn’t be happier.
It was running fine but a bit under powered for my 60” snow-blower, it’s now a torque monster.
I used a waste gated Garrett GT1752 off a Saab that I found at a swap meet.
You will also be happy & probably have a new business supplying turbo kits for Kubota’s!
Good luck with Dyno Day. Would like to see the new HP/torque numbers.
90cummins
Made slow progress today. Things are tight fit wise for the oil cooler.
Hey .020" clearance is as good as a foot as long as it doesn't touch.
Startup will have to wait another week.
Fred
Tight fit for the oil filter/hood. Not sure what to do here. Looking at parts online shows L5740 same oil filter adapter. Wondering if the hoods are way different in this area; they are 1 part number off.
Fred
Any replies considered, except torch :)
   / I Still Hate My Tractor #366
You could always bulge it out a little in that area.. simple rap with a body hammer would do it :)
   / I Still Hate My Tractor #368
I think the hood is wider on the l5740. You see some tractors that the side panel is cut out to fit the filter. A nicely contoured cut would look fine.
   / I Still Hate My Tractor #369
Agreed, a nice 1/2 or so around the filter, would still look good and you can always replace the panel again if you had to.
Use a smaller filter so the panel can be installed correctly then run a marker around the filter from the inside , cut it then install the larger filter again.
   / I Still Hate My Tractor #370
This thing is gonna be awesome!
Status
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
Wooden Swing Bench (A55853)
Wooden Swing Bench...
Ford 8510 (A53317)
Ford 8510 (A53317)
