I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor
That fits in there pretty nice, looks really good. Did you have to make that manifold hieght extension?
Yes the extension is 35mm ID and 1/8" wall, hoping it takes the heat. I will build more support in later. While the turbo looks heavy it is lighter than the original muffler it replaced that had zero support other than the manifold. I truly wanted the turbo to bolt directly to the exhaust manifold but then the oil drain would have to go down to the oil pan. Remember I didn't want to hack the pan and couldn't uncover the factory oil drain for this block which I believe is the dipstick tube access (although covered by the tractor frame rail). Turbo flange is different bolt pattern than the exhaust manifold also. I suspect the Bobcat manifold is a spendy unit. Another problem I encountered is the fuel tank shield, I couldn't sneak the turbo in under it without modifying it, also the reason I went with a pedestal mount. My air intake pipe is mounted very rigidly and the short intake connector will act as more support and hopefully vibration protection.
I used the valve cover for the drain, it is a very short run and the VW TDI turbo drain hose I hacked up (used part I had) looks like it will work ok, red hose is Gates multi-use hose. I use it for transmission line and fuel line in some applications. It should take the heat and petroleum product hopefully. This turbo should pass a small oil amount compared to a larger unit. Not too worried about the heat in the valve cover or oil drain there is plenty of windage space for the oil drain, also a nicely engineered baffle under the valve cover.
Sorry if I didn't answer any pertinent questions, busy day yesterday then company arrived and out came the beer. 10 inches snow here this morning looks like the hand shovel comes out :(
Fred, back on this today hoping to get a test run out of it with a temporary straight pipe until I find a nicely built short and 304 stainless glasspack so I can fab a sweet little quiet exhaust package. While I liked much noise in my younger days quiet is much nicer nowadays. Every now and again at work a Harley will drive by with bone stock pipes and sounds oh so sweet, usually driven by women.
   / I Still Hate My Tractor #362
Hi Fred;
Just found this thread, quite entertaining so I posted to encourage & receive the latest posts.
I installed a turbo on my Ford 1720 a couple years ago & couldn’t be happier.
It was running fine but a bit under powered for my 60” snow-blower, it’s now a torque monster.
I used a waste gated Garrett GT1752 off a Saab that I found at a swap meet.
You will also be happy & probably have a new business supplying turbo kits for Kubota’s!
Good luck with Dyno Day. Would like to see the new HP/torque numbers.
90cummins
Made slow progress today. Things are tight fit wise for the oil cooler.
Hey .020" clearance is as good as a foot as long as it doesn't touch.
Startup will have to wait another week.
Fred
Tight fit for the oil filter/hood. Not sure what to do here. Looking at parts online shows L5740 same oil filter adapter. Wondering if the hoods are way different in this area; they are 1 part number off.
Fred
Any replies considered, except torch :)
   / I Still Hate My Tractor #366
You could always bulge it out a little in that area.. simple rap with a body hammer would do it :)
   / I Still Hate My Tractor #368
I think the hood is wider on the l5740. You see some tractors that the side panel is cut out to fit the filter. A nicely contoured cut would look fine.
   / I Still Hate My Tractor #369
Agreed, a nice 1/2 or so around the filter, would still look good and you can always replace the panel again if you had to.
Use a smaller filter so the panel can be installed correctly then run a marker around the filter from the inside , cut it then install the larger filter again.
   / I Still Hate My Tractor #370
This thing is gonna be awesome!
Status
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
Deere 35P (A53317)
Deere 35P (A53317)
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
