I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor
way to go, b_ _ _ s to the wall
Hard to beat Chevy power in a 3200 lbs. car. Anywho the cranking compression is 400psi across the board. Manual says 520-580, 370 min. Hard to believe it is that low but still very even. Same gauge on TDI engines reads 380 psi and VW is 19-1 compression ratio. Not sure what the V-2003 is for ratio.
Having an awful time finding the timing window in the bell housing, looks like the loader frame covers it up. This should be fun.
I have a coat hanger in the glow plug hole and a degree wheel but just geeze I wonder if the timing ever gets checked with the engine installed.
Fred
   / I Still Hate My Tractor #112
Sounds like maybe timing didn't get checked on yours? If your comp tester is giving you accurate results, and the engine shows even but close to low end of acceptable range, aren't these reasons to get the timing spec verified to within range, before you do any mods? You may find if the timing is off spec correcting it could solve many of the issues you're experiencing with your tractor? No?
Yes. That's my tomorrow job.
Fred
   / I Still Hate My Tractor #114
Compression ratio for the V2003 is 22.8:1. I also have injection pump timing specification in my V series industrial engine manual. Philip.
I just hit the "thanks" button but there isn't one on this forum. Also will do leakdown test tomorrow, I have always felt it is more accurate than compression check. Who knows, Snap-On compression gauge could be off by 100 pounds.
Thanks, Fred
   / I Still Hate My Tractor #116
Yes, but less likely since the numbers are even across the board. I suspect timing issue may present itself because even with lower range of compression readings timing being off could/ would likely cause more symptoms like those you report....
What parameters are Kubota using for their comp specs? Cold engine, operating temp engine, etc.?
   / I Still Hate My Tractor #117
Aaron my Volvo never ran right until I did a V8 conversion on it LOL.
You guys gotta let up on me. You know you wanna see it happen.
Fred
You're right Fred, I was half expecting to see photos of a turbo being dry fit into place this weekend. Sounds like a wise move to double check all the basics before completing the mods.
   / I Still Hate My Tractor #118
Fred
Well Fred if (timing) is affecting cranking compression, it would likely be an incorrectly timed (phased) CAMSHAFT with respect to the crankshaft... which would need to be verified first .. Then the injection timing can be done after crank/cam timing-but injection timing has NO affect on cranking compression.
This engine has how many hours? I recently checked the compression on a 1989 ford F250 7.3 with over 200,000 miles (395-410psi.) and these #s were inline with what you just measured, on this new?? Kubota if both our gauges are accurate something seems wrong... especially if the Kubotas engine has a 22.8 to 1 compression ratio
Looks like you are on the right track...
   / I Still Hate My Tractor #119
Shop manual for the 5740 (turbocharged) shows NO piston cooling jets either. So where are they? Nobody has been able to show me that any Kubota has them. None of the parts pix show piston cooling jets on any of their engines.
Dealer dyno proved this machine and showed me it was within 5% of advertised. I have not checked timing, another good point. The dealer simply gave me all the hoopla that this machine is what it is, an unbroken, working properly unit. It's mine now, I'll deal with it.
Fred
Tore things apart this morning at 5AM. Pulled the fuel tank and A/C bracket, valve cover. Glow plugs ohm fine (0.6 each) and I will do a baseline compression check and timing, valve adj. check before I put it back together. Gonna be a challenge to fit this all and make it look nice and still be able to remove it without remorse if it doesn't work. I see the 5740 has an external EGR to keep NOX down. I think the turbo makes combustion hotter formulating much more NOX. Thanks for the photo, much help.
This Kubota engine is very basic and timeless unlike this new stuff coming down the line.
Why are you checking this stuff if it made within 5% of its advertised power? There is nothing wrong with it.
   / I Still Hate My Tractor #120
Took me a wile to get used to running a tractor at high throttle. After dealing with cars and trucks running 200 RPM under redline does not feel right. I do better now but still only rap it up when necessary.
Pto rpm is 2400rpm on my tractor iirc . For blowing snow the throttle is pinned to the bottom and the tach makes 2800rpm.
Status
2017 Rogator RG1300B Dry Fertilizer Applicator (A55315)
2017 Rogator...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2013 Ford F250 (A55973)
2013 Ford F250...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
John Deere 1025R (A53317)
John Deere 1025R...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
