I want a threaded insert rivet gun - any recommendations?
   / I want a threaded insert rivet gun - any recommendations? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've some applications where I'd like to put threaded inserts into sheet metal, like doors. 1/4 20 bolts would be ideal. HF sells a tool for it (45 Piece Threaded Insert Riveter Kit) but it gets poor reviews.
Anybody have recommendations?
Note - not "normal" rivets, but rivets that accept a threaded bolt in metal sheet (0.30 and thicker).
   / I want a threaded insert rivet gun - any recommendations? #3
A lot of people doing DIY van conversions use Rivnuts.
That might be what he's looking for... I've used the ones for a regular rivet gun but I believe they only go up to 3/16" threaded .
Yes, "Rivnuts" is one brand. But there are a wide variety of tools available (beside just using a threaded rod and 2 nuts) and prices are all over the place.
And reviews from one fellow TBN'er carries more weight than 10 Amazon reviews.
   / I want a threaded insert rivet gun - any recommendations? #7
I needed one to replace some threaded inserts on my jeep. They were put in by some off road shop, but whoever did them messed up about half of them. I got the one from HF and it worked well for the 12-15 that I had to do. I purchased the inserts from Fastenal, much cheaper and better quality. I'm not sure if the HF one will hold up if your going to use it often.
   / I want a threaded insert rivet gun - any recommendations? #8
Ditto on HF. Mine works well. Too bad they don't have a nut assortment. It seems well made and sturdy still working after installing 25 5/16 nuts that I bought from Amazon. Using one can turn a frustrating or 2 person job into a slam dunk. I hope the SS steel nuts are fully annealed. There are air powered ones for production work same as the pop riveters.
Ron
   / I want a threaded insert rivet gun - any recommendations? #9
The threaded insert setter we have at work came from McMaster-Carr and was reasonably priced and easy to use.
   / I want a threaded insert rivet gun - any recommendations? #10
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
