I want a threaded insert rivet gun - any recommendations?
   / I want a threaded insert rivet gun - any recommendations? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've some applications where I'd like to put threaded inserts into sheet metal, like doors. 1/4 20 bolts would be ideal. HF sells a tool for it (45 Piece Threaded Insert Riveter Kit) but it gets poor reviews.
Anybody have recommendations?
Note - not "normal" rivets, but rivets that accept a threaded bolt in metal sheet (0.30 and thicker).
   / I want a threaded insert rivet gun - any recommendations? #3
A lot of people doing DIY van conversions use Rivnuts.
That might be what he's looking for... I've used the ones for a regular rivet gun but I believe they only go up to 3/16" threaded .
Yes, "Rivnuts" is one brand. But there are a wide variety of tools available (beside just using a threaded rod and 2 nuts) and prices are all over the place.
And reviews from one fellow TBN'er carries more weight than 10 Amazon reviews.
   / I want a threaded insert rivet gun - any recommendations? #7
I needed one to replace some threaded inserts on my jeep. They were put in by some off road shop, but whoever did them messed up about half of them. I got the one from HF and it worked well for the 12-15 that I had to do. I purchased the inserts from Fastenal, much cheaper and better quality. I'm not sure if the HF one will hold up if your going to use it often.
   / I want a threaded insert rivet gun - any recommendations? #8
Ditto on HF. Mine works well. Too bad they don't have a nut assortment. It seems well made and sturdy still working after installing 25 5/16 nuts that I bought from Amazon. Using one can turn a frustrating or 2 person job into a slam dunk. I hope the SS steel nuts are fully annealed. There are air powered ones for production work same as the pop riveters.
Ron
   / I want a threaded insert rivet gun - any recommendations? #9
The threaded insert setter we have at work came from McMaster-Carr and was reasonably priced and easy to use.
   / I want a threaded insert rivet gun - any recommendations? #10
2017 Ford F-150 (A53422)
2017 Ford F-150...
CAT 336E (A55745)
CAT 336E (A55745)
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2015 PETERBILT 579 TANDEM AXLE SLEEPER (A56138)
2015 PETERBILT 579...
