I want a threaded insert rivet gun - any recommendations?
   / I want a threaded insert rivet gun - any recommendations? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've some applications where I'd like to put threaded inserts into sheet metal, like doors. 1/4 20 bolts would be ideal. HF sells a tool for it (45 Piece Threaded Insert Riveter Kit) but it gets poor reviews.
Anybody have recommendations?
Note - not "normal" rivets, but rivets that accept a threaded bolt in metal sheet (0.30 and thicker).
   / I want a threaded insert rivet gun - any recommendations? #3
A lot of people doing DIY van conversions use Rivnuts.
That might be what he's looking for... I've used the ones for a regular rivet gun but I believe they only go up to 3/16" threaded .
Yes, "Rivnuts" is one brand. But there are a wide variety of tools available (beside just using a threaded rod and 2 nuts) and prices are all over the place.
And reviews from one fellow TBN'er carries more weight than 10 Amazon reviews.
   / I want a threaded insert rivet gun - any recommendations? #7
I needed one to replace some threaded inserts on my jeep. They were put in by some off road shop, but whoever did them messed up about half of them. I got the one from HF and it worked well for the 12-15 that I had to do. I purchased the inserts from Fastenal, much cheaper and better quality. I'm not sure if the HF one will hold up if your going to use it often.
   / I want a threaded insert rivet gun - any recommendations? #8
Ditto on HF. Mine works well. Too bad they don't have a nut assortment. It seems well made and sturdy still working after installing 25 5/16 nuts that I bought from Amazon. Using one can turn a frustrating or 2 person job into a slam dunk. I hope the SS steel nuts are fully annealed. There are air powered ones for production work same as the pop riveters.
Ron
   / I want a threaded insert rivet gun - any recommendations? #9
The threaded insert setter we have at work came from McMaster-Carr and was reasonably priced and easy to use.
   / I want a threaded insert rivet gun - any recommendations? #10
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
1992 Ford LT9000 T/A Day Cab Truck Tractor (A55852)
1992 Ford LT9000...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55314)
2019 Krause...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
