ID of pump and usage
   / ID of pump and usage
FYI: my splitter is home built, dual way splitter which currently runs of the hydraulics of my John Deere 4100. i'm guessing near
18 tons. I use a standard 20"inch throw cylinder with a 3" shaft. It does good. But would much rather run it off the PTO so I can leave the FEL mounted. I know I can add Power Beyond to the rear. But the small hoses that uses. I feel will slow it down to much
   / ID of pump and usage #12
2500 Max Continuous PSI
3000 RPM Max
Cubic Inch Displacement: .43
Theoretical flow rate at 1750 rpm = 3.2 GPM
Mount: SAE A
Shaft: 5/8" 9-Tooth splined shaft, 1.25" length
#12 in / #10 out SAE o-ring side port
Rotation: CCW / Left-hand
CID .43.......Gonna run slow for a log splitter.....why not just buy the right 2-stage pump and go split wood?
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
