Ideas for a big lawn roller
   / Ideas for a big lawn roller #31
http://www.tractorbynet.com/forums/build-yourself/204021-how-i-roll-lawn-roller.html
   / Ideas for a big lawn roller #32
I filled my garden tractor/mower tires with antifreeze which worked very well for the lawn and traction when blowing snow.
   / Ideas for a big lawn roller #33
I like rollers for early spring when the ground is very soft. It doesn't take a lot of weight to pound the bumps down then.
For larger issues I scrape or fill.
   / Ideas for a big lawn roller #34
I'll throw out another option that I have experience with and that is to use an areovator. Expensive to purchase, but easy enough to find for rent. I own a small towbehind one and it will smooth and loosen up the soil at the same time. A areovator works by vibrating tines that penetrate the soil as it is towed behind. The tines are about 6in long and mounted on a rotating shaft in a concentric manner. As the shaft spins the tines just sort of roll along, vibrating from side to side. This movement helps the tines penetrate deep into the soil, fractureing it in every direction, and the vibration will help knock down the high spots. I use mine for planting grass seed. I broadcast the seed before running over the area with the areovator. Best method I have ever found for overseeding a old lawn, and works pretty durn good for a new lawn as well.
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2025 Future 72in Log Grapple Skid Steer Attachment (A55787)
2025 Future 72in...
Jumper Cables (A53316)
30007 (A53424)
30007 (A53424)
New Holland 750HD Head W/Ez-Trail Head Cart (A50775)
New Holland 750HD...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
