IDEAS ON COUPLING HYD PUMP TO 2.3 FORD
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #11
A 11 GPM pump, 3000 psi, requires about a 23 HP engine.
JJ, would 3000 psi be on the high side to be running on a vane pump? I always heard 1500 is the range you would want to be at for a vane pump or they will not last long.
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #14
ALKY ,
What is the model number on that 11 GPM pump?
The # is V201P11P1C11 11GPM@1200RPM CW Rotation SAE A Flange 2500rpm max 2500psi max. On the electric it was direct drive with lovejoy couplers. thanks guys :cool:
2018 FORD F-350 (A55745)
2018 FORD F-350...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55302)
2017 KINZE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2008 Chevrolet Uplander LS Van (A55853)
2008 Chevrolet...
