IDEAS ON COUPLING HYD PUMP TO 2.3 FORD
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #11
A 11 GPM pump, 3000 psi, requires about a 23 HP engine.
JJ, would 3000 psi be on the high side to be running on a vane pump? I always heard 1500 is the range you would want to be at for a vane pump or they will not last long.
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #14
ALKY ,
What is the model number on that 11 GPM pump?
The # is V201P11P1C11 11GPM@1200RPM CW Rotation SAE A Flange 2500rpm max 2500psi max. On the electric it was direct drive with lovejoy couplers. thanks guys :cool:
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2021 Kenworth T800 Tri-Axle Heavy Haul Truck, VIN # 1XKDP4EXXMR429579 (A54865)
2021 Kenworth T800...
(4) New Winch Straps (A54865)
(4) New Winch...
Hyster 80 Forklift (A54865)
Hyster 80 Forklift...
20357 (A55758)
20357 (A55758)
