IDEAS ON COUPLING HYD PUMP TO 2.3 FORD
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #11
A 11 GPM pump, 3000 psi, requires about a 23 HP engine.
JJ, would 3000 psi be on the high side to be running on a vane pump? I always heard 1500 is the range you would want to be at for a vane pump or they will not last long.
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #14
ALKY ,
What is the model number on that 11 GPM pump?
The # is V201P11P1C11 11GPM@1200RPM CW Rotation SAE A Flange 2500rpm max 2500psi max. On the electric it was direct drive with lovejoy couplers. thanks guys :cool:
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A54865)
2004 Ford F-350...
Kubota LA1055 (A53314)
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2018 2018 JOHN DEERE 410L BACKHOE (A52706)
2018 2018 JOHN...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55302)
BOSS 990 Fuel...
