IDEAS ON COUPLING HYD PUMP TO 2.3 FORD
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #11
A 11 GPM pump, 3000 psi, requires about a 23 HP engine.
JJ, would 3000 psi be on the high side to be running on a vane pump? I always heard 1500 is the range you would want to be at for a vane pump or they will not last long.
   / IDEAS ON COUPLING HYD PUMP TO 2.3 FORD #14
ALKY ,
What is the model number on that 11 GPM pump?
The # is V201P11P1C11 11GPM@1200RPM CW Rotation SAE A Flange 2500rpm max 2500psi max. On the electric it was direct drive with lovejoy couplers. thanks guys :cool:
40 Dry Van Enclosed Trailer (A54865)
40 Dry Van...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
17101 (A55787)
17101 (A55787)
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
