Identify this Grass Catcher
/ Identify this Grass Catcher #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
I found this grass catcher with hydraulic dump on-line wonder if anyone can identify it. I will be going to look at it this evening. I am thinking if it can be modified to fit the 3ph of my TC-18 it would be much better than using my old lawn sweeper.
/ Identify this Grass Catcher #2
It is off of a Ford CM224/274 commercial mower. It would probably be a little heavy when full on a TC18, but could probably modified to attach.
Thanks for the info. I went and took a lool it the other evening and it was much larger than expected.
Generac QT04854 Anax 48kW Generator (A61572)
Generac QT04854...
UNUSED ATSPOWER ATS-SP50 50 TON HYD SHOP PRESS (A64281)
UNUSED ATSPOWER...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
