If you could what would you change
   / If you could what would you change #41
On my BX I'd like real oil pressure, water temperature, and voltmeter gauges like the old Steward Warner type. I would also like a relative height indicator on the mower deck. I have several locations in my yard where I would like to raise the cutting height about an inch or so and it's difficult to judge. My old 1572 Cub Cadet has a height indicator that works great. I second the parking break indicator.
kj
   / If you could what would you change #42
Some indication that the brake is set (light or beeper) so I don't drive away with the brake set. Also the tilt steering wheel lock lever (on B3030) mounted a little higher up so I don't unintentionally hit it with my foot during operation.
Absolutely right about the parking brake. Brake set indicator would be nice.
   / If you could what would you change #44
built in seat warmer
We don't need no stinkin' seat warmers here, but I can understand them for up north.
Here, we could use a lighter colored seat. Black is just too hot, especially with shorts.
Yellow wouldn't be right... maybe a very light orange.
Oh, and rear view mirrors.
   / If you could what would you change #45
Some great ideas! I'd like a waterproof tool box, some way to bring tools and a weedwhacker without using the FEL, and a little tray or cubby on the dash for cell phones or misc, Stuff. Other than that, I'm good!
   / If you could what would you change #46
put hooks on the ROPS and you can place your weedwhacker on there :D. Put the hooks on an angle so it won't protrude out too much on the sides. Just remember it's on there while driving.
   / If you could what would you change #47
Amen on the park brake Indicator. I find myself forgetting to release the park brake at times. I am sure that is not good on the tractor.
   / If you could what would you change #48
Oh heck, let it protrude....and keep it running. Let it trim on the run :D
   / If you could what would you change #49
Reduce the pucker factor on the B3030 with the option to have the rear wheels at a wider stance.
And yes, vertical exhaust pipe.
Otherwise, a great machine.
   / If you could what would you change #50
Why the desire for a vertical exhaust? To me, after bending the vertical exhaust on my M4700 on low branches, I think the below engine exhaust is an improvement.
Ken
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
Can-Am Defender 11000 (A59814)
Can-Am Defender...
