ignition left on, now won't start with key.
   / ignition left on, now won't start with key. #31
yep.. post 6 called out the pto.
look at it like this.
you found it.
now you are good to go.. and wasn't a lot of money or hassle invested.. plus it kept us busy for a few days. :)
glad you got it.
soundguy
I had a little time today. Spent a couple hours trying to trace down the problem. I went to my cub dealer and he had an electrical system diagram he printed out for me.
One of the mechanics happened to walk by and the counter guy asked him his opinion on what might be wrong. First thing he said was make sure your PTO lever is not engaged, he said they get about four or five tractors a year brought in because they won't start because the PTO is engaged.
WELL the very little light went off in my head, that is one thing I had not checked. I still have to find the switch, I missed it when tracing the wires. Got home first thing I did was go to the shed, sure enough the PTO was engaged. Disengaged it and it fired right up.
I know people told me to check everything, I wasn't even aware there was a safety switch on the PTO. Just totally spaced it out.
Now I really feel like a dumb arse, the wife said no one needed to know. I told her that I had posted my problem on the tractor forum and it would be just rude not to let the posters know the out come.
In my defense I only use the PTO for my snow blower and that is not mounted yet. It was my sisters boyfriend that put in gear, but he was doing me a favor by giving me a set of forks from a fork lift so I can not even be mad at him.
Thanks again for all the help.
   / ignition left on, now won't start with key. #32
Join the club, we have t-shirts:D I had many of these moments over the time. Like taking a compressor for busted for good - and it was just the overheating protection. Did not use my compressor for a year or so.
   / ignition left on, now won't start with key. #33
PTO switch interlock on>?
OMG! You're the first one in the history of tractors to ever make that mistake.
(not!:laughing:)
In fact, I use the mid-pto switch on some machines to prevent un-authorized use as it's a hard one to see.
The PTO switch is one that bites many of us on occasion.
Yep, after the mechanic said it I remembered it had already been said here. I just plain forgot to look for it after the post. I think from now on when (not if) I have a problem I will have to print out the replies and bring them with me to the shed.
Thanks for all the help, this is a great forum. One that is not to heavily regulated by the mods. There is another forum I used to visit more often (not a tractor forum) but when ever there would be disagreement between two members that would go on for more than a couple of post they would kill the thread.
   / ignition left on, now won't start with key. #35
This kind of situation is an example where a good electrical schematic would come in handy, and a VOM.
Durning my Navy days as an electronics technician, I remember is electronics school, the instructors would put troubles in the radios and navigation units. Like cutting a wire and sliding the insulation over the cut, adding in the wrong resistor, cold solder joint, a faulty switch, etc.
Without a schematic we would be almost totally lost.
With the tractor scenario.
The little beeper I mentioned above, would have found the problem, because the signal would have stopped at the PTO switch.
In an unrelated electrical problem. I had a Toyota Camry, lost all power to dash, electric door locks, windows motors, Kept blowing fuses. Sure I could trace wires. Getting to the wire bundles was a big problem. Gave up for a while, and one day I thought to search the Internet for Toyota electrical problems, Read some interesting problems and fixes, and one of those was to check the wire bundle by the trunk hinge for abrasion. Sure enough, I could see the copper wire that was causing all the problem. Secured it down to the sidewall, and everything was good.
I will definitely have to get a good manual for the tractor.
What type/brand of tracer do you have?
   / ignition left on, now won't start with key. #37
I will try and locate it and provide more data.
   / ignition left on, now won't start with key. #38
This is the signal/wire tracer that I have and can be found at Home Depot. I have used it quite a bit. Small and compact, Easy to hook up and trace.
Disconnect the vehicle battery while testing.
Gardner Bender Lan Tracker Wire Tracer, Gardner Bender - GET-4220K at The Home Depot
Here is a similar tester.
Gardner Bender ET64220 Wire Tracker Lan Tracker Wire Tracer #6787691 at HardwareAndTools.com
Thanks, I do see that the tracer got a bad review from the only one that took time to review it.
It sounds like you have had pretty good success with it though.
I have some Home Depot gift certificates that I have had for awhile, maybe this would be something I should get.
   / ignition left on, now won't start with key. #40
You could purchase it and do some test, and check out wiring from different things. like cars, tractors,house wiring. I did a wiring on an F-150 from front to back, and it worked like they said. It is simply using the wire as a transmitter antenna. A good test would be to get a friend and an 8 wire cable and have him select a wire to put the transmitter on, and you at the other end find out which wire is the one he selected.
I have several different tracers. A sprinkler system tracer, a circuit breaker tracer, and the little red tracer I use for auto/tractor work.
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
