IH 484 clutch shaft wear question
   / IH 484 clutch shaft wear question #61
What I would do...move the outside lever till you get that 90° angle and then open that plate at the bottom and see if you can messure the distance that the releasebearing is still away from the clutchfingers.
Then open the clutch again and fab a spacer to fit between the releasebearingcarrier and the bearing.
1268 (A50490)
1268 (A50490)
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
John Deere Bale Spear (A55218)
John Deere Bale...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
